R Randy Guest 3/3/21 #1 3/3/21 #1 F-2 The rotating Brake solenoid is abnormal Any suggestions or solutions to fixing this, have had two people look at it, and very frustrated.
LACHAU Administrator Thành viên BQT 3/3/21 #2 3/3/21 #2 Randy nói: F-2 The rotating Brake solenoid is abnormal Any suggestions or solutions to fixing this, have had two people look at it, and very frustrated. Nhấn để mở rộng... Welcome to our forum, Randy. Regarding to F-2 fault code. I suggest you go to service menu (Item No.5) to check first. Đính kèm SK200_210(N)LC-6 Swing Circuit Explaining.pdf 1.2 MB Lượt xem: 23 SK200_210(N)LC-6 Swing Circuit.pdf 2.3 MB Lượt xem: 15
LACHAU Administrator Thành viên BQT 3/3/21 #3 3/3/21 #3 Then check the "SWING PARKING BRAKE RELEASE SWITCH" at rear side of operator. After that, Carefully check wiring, connector and mechanical parts of "SWING PARKING BRAKE SOLENOID". Đính kèm SK210-6 SWING FAULT CODE (3).png 13.1 MB Lượt xem: 23 Sửa lần cuối: 5/3/21
LACHAU Administrator Thành viên BQT 3/3/21 #4 3/3/21 #4 Randy nói: F-2 The rotating Brake solenoid is abnormal Any suggestions or solutions to fixing this, have had two people look at it, and very frustrated. Nhấn để mở rộng... By the way, next time you should mention clearly MODEL of machine. Your machine is SK210-6(E or ES).
Đặng Sơn Moderator Thành viên BQT 3/3/21 #5 3/3/21 #5 Thầy luôn là cánh chim đầu của gia đình mct Sửa lần cuối bởi điều hành viên: 4/3/21
MrB0m_yb New member 6/4/21 #6 6/4/21 #6 Randy nói: F-2 The rotating Brake solenoid is abnormal Any suggestions or solutions to fixing this, have had two people look at it, and very frustrated. Nhấn để mở rộng... Mechatro fault!
Đặng Sơn Moderator Thành viên BQT 21/4/21 #8 21/4/21 #8 MrB0m_yb nói: Mechatro fault! Nhấn để mở rộng... Breacking swing solenoi valve
